LTDC generation code issue
‎2020-11-05 06:45 AM
some thing is strange with the cube ide in the display controller LTDC initialization . i choose 1 layer only but the cube ide generate code for 2 layers!!
First time to see such thing
- Labels:
LCD-LTDC
STM32CubeIDE
STM32CubeMX
‎2020-11-11 03:23 AM
As a workaround , you need to delete the unnecessary code (the wrong config of the unused layer).
Regards,
Khouloud
‎2020-11-05 06:47 AM
Hi @Community member​
Could You please share you ioc file ?
Regards,
Khouloud
‎2020-11-05 06:54 AM
‎2020-11-05 06:57 AM
@Khouloud ZEMMELI​
Also there is problem with the touchgfx it does not set the resolution correctly always fixed at 800 * 480 and also the CUBE ide look change as you see in the photo
‎2020-11-11 02:17 AM
I have the exact same issue, and I'm concerned its affecting performance.
Can anyone help?
‎2020-11-11 02:32 AM
Hi @TWard.1​
Need to know the part number used, the config and the tool version or it will be more better if you share your ioc file.
Khouloud
‎2020-11-11 02:45 AM
‎2020-11-11 02:57 AM
Thanks @TWard.1​
@Community member​ & @TWard.1​ : Issue confirmed and now fixed, the fix will available for the next CubeIDE/MX release (1.5.0 - 6.1.0 ) which will be W47/48.
We are deeply sorry for any inconvenience this may have caused.
Best Regards,
Khouloud
‎2020-11-11 03:14 AM
what is the impact and the workaround? It seems that this is causing my double buffering to not work properly and write to the other layer?
Regards,
Khouloud
