Keil folder doesnt exist
‎2019-03-11 11:07 AM
Hi guys,
I have a STM32L4R9I-DISCO board. I create a touchgfx project from Application Template for this disco board. After that I can run simulator, generate code and run target without problem. I can see my application in disco board's LCD. I will use Keil for code development. I see in the webinar videos there should be a Keil folder in the Target folder . But in my situtation there are "bsp" + "gcc" + "IAR" + "IAR8.x" + "os" + "main.cpp". Why Keil folder can not be created?
Keil
STM32L4 series
TouchGFX
‎2019-03-12 12:52 AM
Hi @Epamuk​,
There currently isn't any Keil project for that application template. There will be with the effort to integrate CubeMX and TouchGFX. I don't think it's something we will do as a standalone effort.
Best regards,
Martin
Hi @Epamuk​,
Best regards,
Martin
