Integrating TouchGFX with TrueStudio Atollic using CubeMX - why is a TouchGFX project not autogenerating?
cusp
I am using CubeMX (MCU = STM32F469ZI) to integrate TouchGFX with Atollic and when I create a project, there seems to be no auto-generated TouchGFX project. I did just a very basic CubeMX project just setting up the peripherals that TouchGFX needs. Then importing the settings using the TouchGFX application screen in CubeMX. Not sure what I am missing, ask me if you need any more info. Thank you.
Martin KJELDSEN
Chief III
Hi @cusp​,
Which version of CubeMX are you using?
Thanks!
