in TouchGFX how to change the default application directory to anything but "C" ?
2019-03-14 11:14 AM
2020-11-11 2:36 AM
Oh, you mean because you can't have spaces in the project folder?
2020-11-11 2:37 AM
If you could provide some detail on your issue i'll use it as ammunition when i talk to the designer guys about it :)
2020-11-12 6:55 AM
I posted the original request WBW(way back when) and I found the solution
I don’t use TouchGFX anymore
Ps you can remove me from the distribution list of touchgfx
2020-11-12 8:56 AM
@Martin KJELDSEN , correct. Spaces are disallowed in the TouchGFX project folder. Image attached to show the error.
@David.Yves use the thread controls to mute the conversation if you don't want updates.
- « Previous
- 1
- 2
- Next »
