2019-12-08 05:06 AM
Is there a specific example of using rtc on touchgfx in its own projects? I am using STM32F746-Disco and I can't use rtc in my project. Can anyone help and publish some functional steps? I'm certainly not the only one to help.
Thank you very much.
2019-12-09 05:07 AM
There's no concrete example of how to use RTC with TouchGFX because it has nothing to do with graphics. If you check out the RTC examples in the Cube firmware packs and find what you're looking for i can help you propagate that data to your TouchGFX UI. You can check out one of the stickies on integrating peripherals with a TouchGFX UI.
/Martin
2019-12-09 09:58 AM
Hi Martin,
with TouchGFX and working with FreeRTOS are just learning to do. I'm not professional. So far I have done simple applications in "C" and with BSP library. On my app I will try to display the time and date with RTC on TouchGFX. I was looking for some examples on the net, but I found nothing. It may be trivial and simple for someone, but I don't know how to do it.
Thank you very much in advance for any help.
Fero
