If possible, how can be anti-aliasing disabled/enabled ?
ferro
Senior III
Hello @ferro ,
No, TouchGFX does not have an option to switch Anti-Aliasing. It is mostly hardware related whether the hardware supports it or not. But, you can disable Dither Algorithm to save up space if you want.
Good luck
Mohammad MORADI
1 REPLY 1
Hello @ferro ,
Good luck
Mohammad MORADI
