IAR Project generation issues
‎2024-10-24 4:23 AM
I'm experiencing issues with TouchGFX file/folder generation.
Below the steps I've followed and issues encountered:
- Create and generate CubeMX project (NUCLEO-U545RE-Q) with TouchGFX, ThreadX and SPI for IAR
- Open touchgfx.part file, add some text on the startup screen, generate code
- Declare the frame buffer in TouchGFXGeneratedHAL.cpp (didn't think of a better way to statically allocate it)
- static uint16_t touchGfxBuffer[145][240];
- Open IAR workspace, compile, following missing files errors
- Fatal Error[Pe1696]: cannot open source file "touchgfx/hal/BlitOp.hpp"
- Fatal Error[Pe1696]: cannot open source file "platform/driver/touch/TouchController.hpp"
- Fatal Error[Pe1696]: cannot open source file "touchgfx/hal/GPIO.hpp"
- Fatal Error[Pe1696]: cannot open source file "touchgfx/hal/HAL.hpp"
- Fatal Error[Pe1696]: cannot open source file "texts/TypedTextDatabase.hpp"
- Fix the path errors adding in preprocessor
- $PROJ_DIR$\..\TouchGFX/generated\texts\include
$PROJ_DIR$\..\TouchGFX/generated\fonts\include
$PROJ_DIR$\..\TouchGFX\generated\gui_generated\include
$PROJ_DIR$\..\TouchGFX\generated\images\include
$PROJ_DIR$\..\TouchGFX\gui\include
$PROJ_DIR$\..\Middlewares\ST\touchgfx\framework\include
- Linker errors probably because .cpp modules have not been added in the IAR project by the generator
- Error[Li005]: no definition for "touchgfx::LCD16bpp::LCD16bpp()"
- Error[Li005]: no definition for "touchgfx::HAL::instance"
- Error[Li005]: no definition for "touchgfx::HAL::DISPLAY_WIDTH"
- And more, 26 Li005 errors in total
IAR EWARM 9.50.2
CubeMX 6.12.1
TouchGFX Generator 4.24.1
TouchGFX Designer 4.24.1
Does this work on IAR 8.50?
Please advise.
Best regards,
George
STM32CubeMX
TouchGFX
‎2024-11-05 4:21 AM
Hello @George.P ,
Why do you set the buffer location to "By address" instead of "By allocation". We usually recommend using "By allocation".
TouchGFX does work for IAR 8.50.
Can you do a text search in your folder to look for the function LCD16bpp()?
Maybe you are missing the TouchGFX library (.a file), they should be in Middlewares\ST\touchgfx\lib\core\cortex_m33
Software engineer at ST (TouchGFX)
‎2024-11-25 6:22 AM
Hello @George.P ,
Have you been able to move forward on your issue?
‎2024-11-25 10:53 PM
Hello, @GaetanGodart,
Thank you for your feedback.
No specific reason, I just wanted to make sure the buffer is properly allocated, without searching the generated code for the buffer's location. I'll try it next time to see how it behaves.
I haven't touched the project since my last message a month ago. I'll update once I do so.
Thanks again.
Best regards,
‎2024-11-26 8:01 AM
Ok no problem! :smiling_face_with_smiling_eyes:
