I updated STM32 Cube IDE and i tried to start project using the STM32 discovery board but Touch GFX is disabled and i can not use it. in the previous version every thing was fine.
MSale
11 REPLIES 11
@Martin KJELDSEN​
Thank you. the resolution is low 480*272 now. i am just focusing on having running video from camera with GUI above it for now then i will try to go for higher resolution.
is it possible to use the pixel data widget and if its possible can i put GUIi above it?
Mahmoud
You could use that, or a dynamic Bitmap.
