Apr 26, 2026 08:31 UTC
HRTIM1, TIMA output2 configuration issue
- 2 replies
- 260 views
In CubeMX Version 6.17.0, for STM32G474RET6, HRTIM1, TIMA output2 configuration, set sources is forced to 0 cannot be changed to 1 and it is showing "Set Sources: nothing to set as Dead Time is enabled, Output2 signal is defined based on Output1 Configuration Set Sources" even if Dead time is kept disabled. This issue was not present on previous versions of CubeMX.
