I had posted question regarding the Touch GFX and LwIP over STM32F7508DK.
Has anyone such issue,
Please community help me solve the issue.
i have the attached the link below
‎2022-08-09 2:56 AM
STM32F7 Series
TouchGFX
‎2022-08-09 3:30 AM
- Why are you making a duplicate topic?
- Why cannot you put an appropriate tags to the topics?
- Why cannot you even explain the actual problem?
- What have you done till now to solve the problem?
‎2022-08-10 12:53 AM
Hello Piranha,
Firstly it was a mistake to create duplicate topic.
I am trying to create a prototype with STM32F7508-DK in which i would like to use Touch Display, Ethernet module and Some GPIO and UART for it.
Initially i tried to do an individual setup for every component like Ethernet,GPIO and UART, Touch display. all the setup works when get up as different project for each components. Later i am combining all the components (integrating together) i don't face any problem for Ethernet,GPIO and UART with FreeRTOS. i am able ping to a static IP and receive back the ping do rest of my task.
But the problems arises when i tired to integrate the touch display and other components mainly with Ethernet module. i do the same process here include the components from CubeMX after creating Touch GFX project. and now when i try to ping their is no response at all.
I see that some memory configuration is done the Touch GFX project itself even for LwIP and it is same and correct what is necessary.
i am currently following this tutorial https://www.youtube.com/watch?v=6olMulM5SCg&list=PLfIJKC1ud8ggZKVtytWAlOS63vifF5iJC&index=23 for seting the Ethernet as i am using the same Development Kit and it works without Touch display, But fails when i create a project from Touch GFX and follow the procedure.
if needed i can provide demo project files for both the scenario.
I hope i have tired to explain the problem faced by me. (is it possible to activate touch display and Ethernet for this Kit).
With Regards
Lakshminarayana KS
