How to use TouchGFX in hierarchical structure. Why the model class is so deeply inside the framework and cannot easily been inherithed? Are there any suggestion? It is impossible to use a factory pattern in such way. Best regards
FMarr.2
1 REPLY 1
MM..1
Chief II
Try explain more for what you need inherit model?
