2023-05-20 10:10 AM - edited 2023-11-20 05:00 AM
2023-05-22 05:05 AM - edited 2023-11-20 05:00 AM
Hello @CSche.4,
That can be easily done by opening the "Apps & features" settings pane of Windows.
You can simply write "Add or remove programs" in the Windows search bar.
Then search "TouchGFX" in the programs list, select the version you wanna delete, click "Uninstall", and follow the instructions on the screen.
Let me know if you have issues doing that.
/Yoann
2023-05-22 06:45 AM - edited 2023-11-20 05:01 AM
Yes, all of this I have tried. it still gets the same error when trying to remove either the 4.19 or 4.20.
2023-05-22 06:59 AM
What does the path of your TouchGFX installation look like ?
/Yoann
2023-05-22 10:26 AM - edited 2023-11-20 05:01 AM
current installation is:
F:\TouchGFX\4.21.3\env\MinGW\msys\1.0\msys.bat
it seems a residue of directories are left behind with each uninstall.
But 4.19, 4.20 will not disappear at all .
