How to solve the Enum in struct build error
‎2022-10-02 10:14 PM
Not sure what I am doing wrong here in my header file. I have a struct pump_info which has some enums as properties. I get a build error on all 3 on the enums in the struct.
Error
'operation_mode' does not name a type
'operation_function' does not name a type
#ifndef PUMPINFO_H
#define PUMPINFO_H
#include "time.h"
enum pump_function {
pump_function_off = 0, pump_function_manual = 1, pump_function_automatic = 2
enum operation_status {
operation_status_off = 0, operation_status_on = 1
enum operation_mode {
operation_mode_standby = 0, operation_mode_duty = 1
struct pump_info {
pump_function pump1Function;
operation_status pump1OperationStatus;
operation_mode pump1OperationMode;
float pump1Current;
unsigned long pump1RunHours;
tm pump1LastRunDateTime;
pump_function pump2Function;
operation_status pump2OperationStatus;
operation_mode pump2OperationMode;
float pump2Current;
unsigned long pump2RunHours;
tm pump2LastRunDateTime;
#endif // PUMPINFO_H
- Labels:
STM32CubeIDE
STM32H7 Series
TouchGFX
‎2022-10-02 10:49 PM
Your enums are not typedefed, so you need to use them with enum keyword.
struct pump_info {
enum pump_function pump1Function;
enum operation_status pump1OperationStatus;
enum operation_mode pump1OperationMode;
Or you can typedef them, and then use w/o enum keyword.
typedef enum pump_function {
} pump_function_t;
typedef enum operation_status {
} operation_status_t;
} operation_mode_t;
You then use them as
struct pump_info {
pump_function_t pump1Function;
operation_status_t pump1OperationStatus;
operation_mode_t pump1OperationMode;
Your personal choice.
struct pump_info {
} pump_function_t;
} operation_mode_t;
struct pump_info {
‎2022-10-02 10:54 PM
@Tilen MAJERLE​ thanks heaps.
‎2022-10-04 12:03 AM
Update:
typedef did not work, build warning error
warning: 'typedef' was ignored in this declaration
this worked
struct pump_info {
