2021-07-05 2:29 AM
Now I am thinking about adding animations when screen startup and normal screen , is there any implement in touchgfx? If not, I want to know if it is feasible to decode images from some format like GIF and just show them by order to realize this? Or do u have any other solutions?
/JJ.Lin
2021-07-05 3:13 AM
You can use the "animated image" widget which can work as a gif. You will need to divide the gif/video into multiple pngs.
/Romain
