2020-04-22 8:02 AM
Hi.
Is it possible to re-use some of the screens of previously developed TouchGFX project ?
I have tried the option of importing the GUI but it overwrites my current project.
Please share your thoughts or suggestions.
Shree
2020-04-23 1:19 AM
Unfortunately it is not possible to just copy and transfer a screen to another project. The only solution is to re-use your code.
Importing a UI overwrites the UI that is already present.
/ Romain
2020-04-23 1:19 AM
/ Romain
2020-04-23 1:21 AM
Thanks Romain.
2020-04-27 3:35 AM
Not to mention that importing a UI will only import the screen definition. This means the generator can generate the code for the UI but not the logic you wrote yourself inside the files in gui/.
You could write some fancy scripts though :) Having a repository of widgets and screens is something we want to look at.
/Martin
