How to re-use some screens from previous project ?
Shree
Hi.
Is it possible to re-use some of the screens of previously developed TouchGFX project ?
I have tried the option of importing the GUI but it overwrites my current project.
Please share your thoughts or suggestions.
Shree
Romain DIELEMAN
Unfortunately it is not possible to just copy and transfer a screen to another project. The only solution is to re-use your code.
Importing a UI overwrites the UI that is already present.
/ Romain
3 REPLIES 3
Romain DIELEMAN
/ Romain
Thanks Romain.
Martin KJELDSEN
Chief III
Not to mention that importing a UI will only import the screen definition. This means the generator can generate the code for the UI but not the logic you wrote yourself inside the files in gui/.
You could write some fancy scripts though :) Having a repository of widgets and screens is something we want to look at.
/Martin
