How to communicate an MCU to the STM32F746 DISCO using UART
ferdlf
Hi, I want to conect an external MCU to the STM32F746 DISCO using UART but I dont know how to use another UART other than the one used for communication with the PC.
STTwo-32
Hello @ferdlf
As said @Andrew Neil, all UARTs work almost the same. I suggest you to take a look at this example to understand how it should be configured.
Best Regards.
STTwo-32
2 REPLIES 2
It's used just the same as the one for communication with the PC.
You allocate available IO pins, and then connect those pins to the other MCU.
STTwo-32
Hello @ferdlf
Best Regards.
STTwo-32
