How to access TextBuffer using pointer
SKokk.1
On a working project with TouchGFX, i have over 150 TextBuffers (wildcards) which i access and change/edit on runtime.
Now i am trying to edit some code parts to avoid repeated parts (many IF conditions).
Is there a way to use a table with pointers and access the desired TextBuffer each time;
Alexandre RENOUX
Principal
What's your status ?
Your request does not seem to be related to TouchGFX in particular but more to C++ coding in general.
Have you tried using an array of pointers ?
/Alexandre
Alexandre RENOUX
Principal
/Alexandre
SKokk.1
Sorry, i did not reply back.
Its solved using array of pointers. I had to refresh my C++ classes related part.
