How do I use touchgfx and fatfs together?
Jloda.11
if I add fatfs to touchgfx project, fatfs library doesn't seem to work. if I use fatfs individually it seems to work fine
1 REPLY 1
Hello @Jloda.1​ ,
You could check the following demonstration provided under the H7 Firmware Package ( Path: Projects\STM32H743I-EVAL\Demonstrations\TouchGFX)
This could help you.
BeST regards,
Walid
