2022-09-27 10:41 AM - last edited on 2024-10-10 8:18 AM by Andrew Neil
How can I scale buttoms and sliders at TouchGFX 4.20?
I am using it to code an app for the STM32F746G-DISCO and I want to resize buttoms and sliders.
Is it possible?
2022-09-28 12:43 AM
Hello @Unai Hernández ,
To resize buttons in TouchGFXDesigner, you can use a FlexButton widget. That will enable you to modify the dimensions, and the shape of your button.
For sliders, that will depend on the images you wanna use for Background and Indicator. If you want to increase the size of your widget, choose bigger images or create your own and include them in the project.
Hope that this helps,
/Yoann
2022-09-28 12:43 AM
/Yoann
2024-10-10 8:04 AM
What a piece of ***! You cant even resize buttons, sliders, text boxes to fit on your screen. A total waste of time.
2024-10-10 8:05 AM
I said C R A P !
