How can i flash the colors of the boxes with TouchGFX ?
TSour.1
3 REPLIES 3
Yoann KLEIN
Hello @Community member​ ,
I'm not sure to understand what you mean with "Flash the colors".
Can you please elaborate ?
Thanks,
/Yoann
Yoann KLEIN
TSour.1
Hello @Yoann KLEIN​
thank you for your return, I want to make the color of a block flashes for a specific duration.
I don't know if it's possible !
Thanks,
There is a very easy way to do that :
  • In Screen1View.cpp, implement the handleTickEvent() method (don't forget to declare this function also in the Screen1View.hpp file).
  • In Screen1View.hpp, declare a boolean variable to toggle the color of your widget (e.g. bool toggle=false), and a integer variable that you can initialize at 0 (e.g. int counter=0)
  • Then, in the handleTickEvent() method, you can increment your counter every time the method is called, and implement a switch case mechanism in order to toggle the color of your widget, like this:
counter++;
if(counter%60 == 0) //  toggle color every second
	toggle = !toggle;
	switch(toggle)
	case false:
	box2.setColor(red);
	break;
	case true:
	box2.setColor(blue);
	break;
	box2.invalidate();
	counter=0;
Please note that you can change the blinking rhythm by modifying the "if(counter%60 == 0) " condition (For example : "if(counter%30 == 0)" will enable you to change the color every half second).
Let me know if that helped,
/Yoann
Yoann KLEIN
