Hello, i am tring to display some word on my LCD connected by means I2C drive (LCM1602) without result. I have no error and the LCD is always on but no word apper. I think that the issue is the address to put in:
#define DEVICE_ADDR (0x4E << 1)
‎2022-10-08 10:32 AM
On data scheet of device (PCF8574T mounted on LCM1602) the addres is 0100 1110=4E but the program still doesn't show me any letter on LCD. Where is wrong? I cheked many times the pin and them are right. Same thing on Cube IDE.
‎2022-10-09 5:00 AM
- https://playground.arduino.cc/Main/I2cScanner/ is a link to an I2C scanner.
- Does your display work on a real Arduino, have you tried this?
- Have you tried to change the contrast of your display (via a potmeter or other device), if contrast is not setup correctly you not see anything.
Best Regards,
Johi.
‎2022-10-08 1:07 PM
remove << 1 or better change >> 1
‎2022-10-09 4:49 AM
Hi, i doesn't work
‎2022-10-09 4:50 AM
there is a way to check automatcly the adress like in the arduino? In arduino there is some code to scann this
‎2022-10-09 5:00 AM
Best Regards,
Johi.
‎2022-10-09 5:27 AM
YES i tried to do all; with Arduino i can see some word
