Generate Code \ Failed TouchGfx 4.17
NUDEM
Unable to locate E:/TouchGFX/denmeme34/.cproject
Plase Help//
Hello Alexandre,
I found the error. I changed the language and regional settings from Turkish to English in Win10. Problem is solved. thank you for your concern
Alexandre RENOUX
Principal
Hello NUDEM,
This means that this path is wrong somehow.
With this much information it's unfortunately complicated to provide any help.
How's your project architecture ?
Can you provide a screenshot of the console showing your error ?
/Alexandre
Hello Alexandre,
Hello NUDEM,
Glad to hear you solved the issue ^^
Please close this topic by choosing Select at Best.
/Alexandre
