Gpeti
August 26, 2019
Fill a part of frame buffer with a L8 format color on STM32H7
  • August 26, 2019
  • 3 replies
  • 1088 views
i'm using DMA2D to fill a part of my frame buffer with a single color. Environnement​ is STM32H753, LTDC controller, EVAL2 board with LCD screen.
Until now I was using ARGB8888 format (so both input and output formats were identical in DMA2D setting) but now I switched to L8 format.
I don't understand why there is no "L8" output color format ? I just want the DMA to copy the L8 color index to the buffer in memory, I actually don't need any conversion, nor CLUT.
There is probably something I didn't understand in the DMA2D behaviour.
Thank you
oleksandr.karbivsky
Senior II
August 27, 2019
Hi. In Ref Manual you can find supported output formats on page 709. L8 format is not supported.
You can use MDMA for Memory-to-Memory transaction with 1 byte data size settings.
Gpeti
GpetiAuthor
August 27, 2019
​Thank you for your answer. Would it work for with MDMA ? I thought a benefit of DMA2D is to be able to manage offset (from one image line to another one).
Also I don't really understand why the easiest mode (I mean no color conversion at all) is not supported.
oleksandr.karbivsky
Senior II
August 27, 2019
MDMA also has offset configuration. L8 is not common format for graphical applications.
