Fill a part of frame buffer with a L8 format color on STM32H7
‎2019-08-26 3:23 AM
i'm using DMA2D to fill a part of my frame buffer with a single color. Environnement​ is STM32H753, LTDC controller, EVAL2 board with LCD screen.
Until now I was using ARGB8888 format (so both input and output formats were identical in DMA2D setting) but now I switched to L8 format.
I don't understand why there is no "L8" output color format ? I just want the DMA to copy the L8 color index to the buffer in memory, I actually don't need any conversion, nor CLUT.
There is probably something I didn't understand in the DMA2D behaviour.
Thank you
- Labels:
DMA2D
LCD-LTDC
STM32H7 series
‎2019-08-27 1:24 AM
Hi. In Ref Manual you can find supported output formats on page 709. L8 format is not supported.
You can use MDMA for Memory-to-Memory transaction with 1 byte data size settings.
‎2019-08-27 1:59 AM
​Thank you for your answer. Would it work for with MDMA ? I thought a benefit of DMA2D is to be able to manage offset (from one image line to another one).
Also I don't really understand why the easiest mode (I mean no color conversion at all) is not supported.
‎2019-08-27 7:00 AM
MDMA also has offset configuration. L8 is not common format for graphical applications.
