External flash memory - External loader failure - STM32H735IGTx MX25L12833FM21-10G
dgold.1
I have custom board with MCU STM32H735IGTx connected via OctoSPI to QuadSPI external flash memory MX25L12833FM21-10G
In order to flash the external memory I am using external flash loader based on the template in https://github.com/STMicroelectronics/stm32-external-loader/tree/contrib
When I am running from the embedded SW application the test template (include erase, write and memory mapping) the test pass OK.
When I am running the external loader from the cube programmer the read from 0x90000000 fails
When I am running the external loader from cube IDE I get 'Erasing external memory sectors [0 23] failure
Attached external flash BSP driver mx25l128_quadspi.c , loader template Loader_Src.c and MX driver octospi.c
Help will be highly appreciated!
Best regards
https://github.com/cturvey/stm32extldr/blob/main/h7_mx25l12835f/README.md
https://github.com/cturvey/stm32extldr/blob/main/h7_mx25l12835f/CLIVEONE-MX25L128_STM32H72X-PB2-PC11-PD11-PD12-PE2-PF6.stldr
Ordered some MX25L12833FMI-10G in a SOIC16W form I can fixture
PB2:AF9 CLK
PC11:AF9 NCS
PD11:AF9 D0
PD12:AF9 D1
PE2:AF9 D2
PF6:AF10 D3
MX25L12833FM21-10G SOP8
STM32H735IGTx
1 REPLY 1
PB2:AF9 CLK
PC11:AF9 NCS
PD11:AF9 D0
PD12:AF9 D1
PE2:AF9 D2
PF6:AF10 D3
STM32H735IGTx
