DMA2D: adding transparency to a bitmap - is it possible? ((A)RGB + A8 blending)
2022-12-07 1:12 PM
I have ARGB bitmap image and I would like to blur its edges by applying A8 mask.
Is it possible to do it with DMA2D Chrom-Art? I cannot figure it out.
Note: it is not the same as blending masked solid color with background, e.g. to draw anti-aliased font.
In another words, I want to replace (or mix) my bitmap alpha channel with A8 mask bits without changing RGB values.
- Labels:
DMA2D
STM32F7 Series
2022-12-16 4:35 AM
Hello @TJast,
Could you please provide more details, such as the MCU you are using.
For example with STM32F7, the DMA2D has four operating modes:
- Register-to-memory for rectangle filling operation,
- Memory-to memory for 2D memory copy operations,
- Memory to memory with pixel format conversion for bitmap drawing with format conversion,
- Memory to memory with pixel format conversion and blending for bitmap or text drawing with transparency.
For more explanation, I advise you take a look at this presentation.
Thank you.
Kaouthar
2022-12-16 7:31 AM
@KDJEM.1 Thank you for your answer. The exact MCU I am dealing with is STM32F769NI.
I am aware of the four supported CR modes and three AM (alpha modes). However, it seems to that none of the possible combinations allows to accomplish what I am looking for, that is, combining RGB bitmap with another bitmap containing alpha A8 bytes only WITHOUT blending (A+ARGB->ARGB), just replacing one alpha bitmap value for another.
2022-12-29 5:30 AM
@KDJEM.1 I know the answer- it is not possible as it would require two "foregrounds".
