Memory on dev kit vs image size
‎2024-10-23 6:36 PM - edited ‎2024-10-23 6:44 PM
looking at this dev kit https://www.st.com/en/evaluation-tools/32f469idiscovery.html#overview
it comes with a 800x480 pixels display and the QSPI is "only" 128Mbit.
Am I correct in saying that (without any compression) it can only store just over 10 full screen-sized images assuming 4 bytes per colour (1 layer with transparency)?
128,000,000 / (800 x 480 x 32) = 10.4
That also means no video can be stored (unless you just play a few frames)?
Is that correct or am I missing something?
Thank you :)
- Labels:
LCD-LTDC
‎2024-10-23 10:03 PM - edited ‎2024-10-24 10:19 AM
Video is likely to be a challenge, as you have no CODECs
For larger memory, perhaps Micro SD card.
‎2024-10-23 8:07 PM
I tend to agree with you in case unpacked video used.
If packed video used like MJPEG, video (400x240 size or smaller) may be played back - like the case for some kind of demo from ST.
‎2024-10-24 4:40 AM
Thank you @Tesla DeLorean
