2012-01-23 12:09 PM
Hi, I'm new to STM32 and also to interfacing with Digital camera modules.
as a First step I went trough the DCMI example that boards with the STM32F2xx Library. although in the example firmware that came with the Eval board the camera seems to work fine, but simply running the DCMI example gives no result to the LCD, even though the code runs with no error.I am using IAR EWARM to build and deploy the code to the board.Do I have to make any change in the code to make it work?Thanks in advance #stm3220g-eval #smt3220g #dcmi #dcmi2013-10-12 03:29 AM
2013-10-12 10:18 AM
The forum appears to have eaten your post, please try again.
The Microsoft forum software does not work well with mobile devices, like Android Tablets, but should work with IE or FireFox
