Can't set status of Scroll List when scrolls
NHo.1
Hi ST,
I have 1 problem when uses scrollList (or use scrollable + Listl ayout). I use a button to set visible scroll List to true. When not scroll, it works ok. But when i scroll, it can disable scroll List. Please tell me why?
Martin KJELDSEN
Chief III
Can you rephrase? Your issue isn't completely clear to me.
/Martin
I designs 1 button and 1 scrollList. I codes for button to setVisible scroll List (true or false). If i doesn't scroll, its ok. But if i scrolls this list, it cant setVisible when i press button. Why?
Can you tell us exactly the steps in the right order you do to create your issue so that we can try reproducing it ? Otherwise, you can also enclose your TouchGFX project here. Please only send the gui/ folder, assets/ folder as well .touchgfx file so that it does not become a large size archive.
/Alexandre
