X-CUBE-CRYPTOLIB problem
nima.askari
Hello, I have created an encrypted file by openssl-aes256-CFB. in openssl IV length should be 128 bit but in X-CUBE-CRYPTOLIB it is not possible,  it cannot set to 128 bit, (HARDFAULT). only i can set 256bit and then received error 0x10003
CMYL
Hello @nima.askari, I'm checking with team.
Best Regards,
Younes
CMYL
IV shall be 128 bits (size of an AES block).
If hardfault occurs, then may be be there is an issue in your code/project as the CFB have been deeply tested… !!
Can you share the code + openssl used commands ?
Best Regards
