Why mbedtls, which is part of STCube 1.16 release, does not contain HW acceleration code?
‎2017-05-11 8:47 AM
Recently PolarSSL library has been replaced by mbedtls in STCube Third Party libraries.
PolarSSL used to have STM32 specific code for some of the Polar SSL APIs. Now, in the latest STCube
mbedtls library does not have STM32 specific code which enables usage of hardware HASH and CRYPTO engine.
What is the reason for this ?
Best regards,
Bogdan
#stm32 #crypto #mbedtls #hash- Labels:
Cryptography
‎2017-05-24 2:44 AM
Hi Bodgan,
indeed the mbedtls released within the STM32 Cube FW is without any HW crypto engine integration.This is planned in the next release of the Cube FW.
Notice that integration of the hw crypto won't be integrated in mbedtls source code itself but in the applications source code instead.In fact the mbedtls is offering config flags that allows user to provide alternate functions for crypto functions.
We did that for the Random Number generator, have a look at the files:
Projects/STM32469I_EVAL/Applications/mbedTLS/SSL_Client/Src/hardware_rng.cProjects/STM32469I_EVAL/Applications/mbedTLS/SSL_Client/Src/stm32f4xx_hal_msp.c
regards
Haithem.
‎2017-05-24 8:37 AM
Hi Haithem,
Thanks for the reply. I wander, when do you expect next release of the Cube FW ?
Best regards,
Bogdan
‎2017-06-08 4:18 AM
Hi again,
I have just one more comment about the code in Projects/STM32469I_EVAL/Applications/mbedTLS/SSL_Client/Src/hardware_rng.c.
Following code line is not correct:
memset(&(Output[index * 4]), (int)randomValue, 4);
Since Output is unsigned char* type, the line printed above will fill in the &(Output[index * 4]) with LSB of randomValue.
Here is the correction :
memcpy(&(Output[index * 4]), &randomValue, 4);
Best regards,
Bogdan
‎2017-07-18 8:27 AM
Hi Haithem,
that sounds very interesting!
When do you release the new CubeFW with the alternative enryption functions for 'AES', 'DES', 'SHA1', 'SHA256', ... by using the HW Crypto Engine / acceleration of the STM32F4xx-Family?
Thank you in advance for your reply.
Best regards,
Jo
‎2017-10-25 1:40 AM
@all:
The latest release of STM32CubeMX (v4.23) support mbedTLS middleware now!
‎2017-11-12 11:06 AM
hi,
sorry, the v4.23 is intended to support only the mbedtls without hw crypto.
the hw crypto integration is currently under study
keep you updated!
‎2017-11-16 3:02 AM
Why do you need so much time? It's been almost 6 months since the original post?
You already had this feature for PolarSSL which is
predecessor of mbedTLS...
Best regards,
Bogdan
‎2017-11-23 2:21 PM
Hi ST support team,
We are looking for hard accelerated crypto engine library for mbedTLS for our current project. We are batting on this project just because of AES hardware. Could you please help us when it would be available?
Sam Sangani
‎2017-11-30 6:15 AM
Hi Sam,
I solved my problem with AES hw acceleration by adding following line :
hcryp_aes.Instance = CRYP; before calling HAL_CRYP_Init(&hcryp_aes);. I made this change in aes.c.
Hope this helps!
Best regards,
Bogdan
