Unable to find definition of FW_INFO_TOT_LEN
Arno1
I'm trying to port the SBSFU to STM32H735. I started from the project for the NUCLEO-H753ZI.
I get errors in sfu_fwimg_core.c on FW_INFO_TOT_LEN but where is this defined?
A simple grep -r turns up nothing.
Thanks!
Jocelyn RICARD
Hello Arno,
this symbol is used in SBSFU v2.3.1 but no more in latest version 2.4.0
In previous release you could find
#define FW_HEADER_TOT_LEN        (sizeof(SE_FwRawHeaderTypeDef))   /*!< FW INFO Total Len*/
in sfu_fwimg_internals.h
So, I guess there is a mixup between the 2 releases.
Best regards
Jocelyn
6 REPLIES 6
Jocelyn RICARD
Hello Arno,
Best regards
Jocelyn
Arno1
*removed, should have been reply*
Thank you for the quick response. Does this mean the project for H753 hasn't been updated yet to v2.4.0?
Also I must add, that this could be entirely my error.
Hello Arno,
I think I was not clear. I meant a mixup on your side between the 2 releases.
There were some evolutions between v2.3.1 and 2.4.0 and this symbol is actually no more used in the new 2.4.0.
The evolution impacted all the targets.
Best regards
Jocelyn
Indeed it was. Thanks for the help.
