2020-08-31 11:55 PM
I forgot to comment the protections set in app_sfu.h and tried debugging the code.
Later I realized and commented everything and it is not allowing me to flash the program on the device.
I made RDP level 0 from cube programmer, but still write protection is enabled which is not allowing me to format the device.
Could anyone please let me know how can i remove write protections in cube programmer.
Thanks,
Ankush
2020-09-01 2:12 AM
Hi @ANaga.2
Please try this command" -c port=swd -ob displ "then tell me the output to check the issue.
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer-2.5.0\bin>STM32_Programmer_CLI.exe -c port=swd -ob displ
STM32CubeProgrammer v2.5.0
ST-LINK SN : 0669FF303435554157042733
ST-LINK FW : V2J30M19
Board : NUCLEO-L476RG
Voltage : 3.26V
SWD freq : 4000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID : 0x415
Revision ID : Rev 4
Device name : STM32L4x1/STM32L475xx/STM32L476xx/STM32L486xx
Flash size : 1 MBytes
Device type : MCU
Device CPU : Cortex-M4
UPLOADING OPTION BYTES DATA ...
Bank : 0x00
Address : 0x40022020
██████████████████████████████████████████████████ 100%
Bank : 0x01
Address : 0x40022044
OPTION BYTES BANK: 0
Read Out Protection:
RDP : 0xAA (Level 0, no protection)
BOR Level:
BOR_LEV : 0x0 (BOR Level 0, reset level threshold is around 1.7 V)
User Configuration:
nRST_STOP : 0x1 (No reset generated when entering Stop mode)
nRST_STDBY : 0x1 (No reset generated when entering Standby mode)
nRST_SHDW : 0x1 (No reset generated when entering the Shutdown mode)
IWDG_SW : 0x1 (Software independant watchdog)
IWDG_STOP : 0x1 (IWDG counter active in stop mode)
IWDG_STDBY : 0x1 (IWDG counter active in standby mode)
WWDG_SW : 0x1 (Software window watchdog)
BFB2 : 0x0 (Dual-bank boot disable)
nBOOT1 : 0x1 (Boot from Flash if BOOT0 = 0, otherwise system memory)
SRAM2_PE : 0x1 (SRAM2 parity check disable)
SRAM2_RST : 0x1 (SRAM2 is not erased when a system reset occurs)
PCROP Protection (Bank 1):
PCROP1_STRT : 0xFFFF (0x807FFF8)
PCROP1_END : 0x0 (0x8000000)
PCROP_RDP : 0x0 (PCROP zone is kept when RDP is decreased)
Write Protection (Bank 1):
WRP1A_STRT : 0xFF (0x807F800)
WRP1A_END : 0x0 (0x8000000)
WRP1B_STRT : 0xFF (0x807F800)
WRP1B_END : 0x0 (0x8000000)
OPTION BYTES BANK: 1
PCROP Protection (Bank 2):
PCROP2_STRT : 0xFFFF (0x80FFFF8)
PCROP2_END : 0x0 (0x8080000)
Write Protection (Bank 2):
WRP2A_STRT : 0xFF (0x80FF800)
WRP2A_END : 0x0 (0x8080000)
WRP2B_STRT : 0xFF (0x80FF800)
WRP2B_END : 0x0 (0x8080000)
Best regards,
Nesrine
2020-09-01 1:58 AM
Hello @ANaga.2 ,
Could you please give me more details about the Board name used .
Best regards,
Nesrine
2020-09-01 1:59 AM
Its L476RG
2020-09-01 2:12 AM
Hi @ANaga.2
Voltage : 3.26V
SWD freq : 4000 KHz
Device ID : 0x415
Revision ID : Rev 4
Device type : MCU
Bank : 0x00
Bank : 0x01
BOR Level:
User Configuration:
Best regards,
Nesrine
2020-09-02 4:56 AM
It worked. Thank you so much
2022-12-22 2:05 AM
Hello everyone, We were testing out the SBSFU example for our 2 running projects.
But currently, we are unable to upload any other program to the device.
Here is the STM32CubeProgrammer log for "Full chip erase" request
15:26:43:686 : MASS ERASE ...
15:26:43:693 : Flash erase...
15:26:43:694 : halt ap 0
15:26:43:716 : Init flashloader...
15:26:43:716 : halt ap 0
15:26:43:718 : run ap 0
15:26:43:735 : halt ap 0
15:26:43:735 : Loader mass erase...
15:26:43:737 : run ap 0
15:26:43:737 : halt ap 0
15:26:43:737 : Error: Mass erase operation failed.Please verify flash protectionAnd below CLI output is given
Please have a look and suggest us to resolve this.
./STM32_Programmer_CLI -c port=swd -ob displ
STM32CubeProgrammer v2.12.0
ST-LINK SN : 0671FF313736504157192620
ST-LINK FW : V2J40M27
Board : NUCLEO-G070RB
Voltage : 3.23V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device name : STM32G07x/STM32G08x
Flash size : 128 KBytes
Device type : MCU
Device CPU : Cortex-M0+
BL Version : 0xB2
Debug in Low Power mode enabled
Bank : 0x00
[==================================================] 100%
BOR Level:
BOR_EN : 0x0 (Configurable brown out reset disabled, power-on reset defined by POR/PDR levels)
BORR_LEV : 0x0 (BOR rising level 1 with threshold around 2.1 V)
BORF_LEV : 0x0 (BOR falling level 1 with threshold around 2.0 V)
User Configuration:
RAM_PARITY_CHECK: 0x1 (SRAM parity check disable)
nBOOT_SEL : 0x1 (BOOT0 signal is defined by nBOOT0 option bit)
nBOOT0 : 0x1 (nBOOT0=1)
NRST_MODE : 0x3 (Bidirectional reset: NRST pin configured in reset input/output mode (legacy mode))
IRHEN : 0x1 (Internal resets drives NRST pin low until it is seen as low level)
PCROP Protection:
PCROP1A_STRT : 0xFF (0x801FE00)
PCROP1A_END : 0x0 (0x8000200)
PCROP1B_STRT : 0xFF (0x801FE00)
PCROP1B_END : 0x0 (0x8000200)
Write Protection:
WRP1A_STRT : 0x0 (0x8000000)
WRP1A_END : 0x1F (0x800F800)
WRP1B_STRT : 0x3F (0x801F800)
FLASH security:
BOOT_LOCK : 0x0 (Boot based on the pad/option bit configuration)
SEC_SIZE : 0x20 (0x8010000)
