ā2019-12-16 03:14 AM
Hi everyone,
I was trying to protect my code by read out protection. But before uploading program, mistaken changed the read out protection to level 2 using of stm32 utility software. Now, I don't able to connect my board to st-link.
After search for this issue, i find that it is irreversible process means i can't program again.
Anyone has any idea?
ā2019-12-16 05:16 AM
Level 2 is indeed irreversible, and debug access is disabled. Hence,your board is now for the bin ...
Never, ever set the readout protection while developing. That's the very last step of pre-production test.
ā2019-12-16 03:55 AM
Not sure about the F7 and it's specific RDP levels. Some MCUs "allow" for an unrecoverable protection, check the datasheet/reference manuals.
So yes, you might have bricked your board.
The usual way is to boot into system mode (BOOT0/BOOT1 pins), and do a Flash mass erase.
The current tool of choice for the mass erase is AFAIK the CubeProgrammer, albeit I never used it personally.
ā2019-12-17 08:51 PM
Thanks for the confirmation.
I broke my board .
