How can we debug the below projects on Keil IDE? - SBSFU project - Our main project while it is ported to SBSFU
ali rostami
I need to debug the SBSFU project on the Keil IDE. I know there are some data about IAR and Cube but I couldn't find anything about Keil.
After that, I also want to debug my main project while it is located in slot 1.
So How is it possible?
Jocelyn RICARD
Hello Ali,
you can start debugging SBSFU and then load your application symbols using the command :
LOAD <User application axf> INCREMENTAL
Best regards
Jocelyn
