B-U585I-IOT02A definitely locked?
‎2022-11-29 7:54 AM
Hello STM32U5 community,
I was making a few attemps with my B-U585I-IOT02A demo board and TF-M. I am afraid I have irreversibly locked the MCU.
Here is what I did:
- run regression.sh
- set RDP level 1 with the Programmer despite the warnings, because I forgot that regression.sh had erased the Secure and NSecure applications.
Now I fail to reconnect with the MCU by any means. What can I do? TZEN/RDP regression with boot from RSS? AN5347 says "a small rework" must be done. I would appreciate a step by step instruction.
Regards.
STM32U5 series
TFM
‎2022-11-29 8:43 AM
Hi @ELuca.2​
To solve the issue you need to:
- Switch the BOOT0 pin to 1 with the connector SW1 on your board
- Connect your board with STM32CubeProgrammer
- In the option bytes section :
- Switch the RDP value to Level 0, no protection in the Read Out Protection panel
- Uncheck the TZEN value to disable it, in the User Configuration panel
- Then click on Apply to program the Option bytes.
- You can now disconnect and switch BOOT0 to 0 with SW1 and connect again
You need to Switch the RDP value to Level 0 and Uncheck the TZEN value before programming the option bytes, otherwise it won't work.
Best Regards,
A.MVE
‎2022-11-29 8:43 AM
Hi @ELuca.2​
Best Regards,
A.MVE
‎2022-11-29 9:11 AM
Thanks A. MVE.
It worked! I was a bit confused because CubeProgrammer raised some reading error messages at connection time. But apparently it was still able to change RDP/TZEN.
‎2022-11-30 12:32 AM
Hi @ELuca.2​ ,
I am glad to heard it ;) .
To let the others STM32U5's users find the thread, select the answer as best.
Best Regards,
A.MVE
