Wrong FLASH_ACR->LATENCY bit in stm32f103xe.h?
Peter Kietzmann
Posted on December 22, 2016 at 13:22
Section 3.3.3 of the reference manual (RM0008, Rev16) for STM32F10XXX MCUs explains in the register description for FLASH_ACR->LATENCY:
Bits 2:0 LATENCY: Latency
These bits represent the ratio of the SYSCLK (system clock) period to the Flash access time.
000 Zero wait state, if 0 < SYSCLK≤ 24 MHz
001 One wait state, if 24 MHz < SYSCLK ≤ 48 MHz
010 Two wait states, if 48 MHz < SYSCLK ≤ 72 MHz
If I see it correctly, the CMSIS header stm32f103xe.h defines odd bits for this purpose:
#define FLASH_ACR_LATENCY_0                 (0x1U << FLASH_ACR_LATENCY_Pos)    /*!< 0x00000001 */
#define FLASH_ACR_LATENCY_1                 (0x2U << FLASH_ACR_LATENCY_Pos)    /*!< 0x00000002 */
#define FLASH_ACR_LATENCY_2                 (0x4U << FLASH_ACR_LATENCY_Pos)    /*!< 0x00000004 */
In previous versions of the header file this wasn't the case, even thought the documentation of these bits appears a bit confusing:
  * @file    stm32f10x.h
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    11-March-2011
#define  FLASH_ACR_LATENCY                   ((uint8_t)0x03)               /*!< LATENCY[2:0] bits (Latency) */
#define  FLASH_ACR_LATENCY_0                 ((uint8_t)0x00)               /*!< Bit 0 */
#define  FLASH_ACR_LATENCY_1                 ((uint8_t)0x01)               /*!< Bit 0 */
#define  FLASH_ACR_LATENCY_2                 ((uint8_t)0x02)               /*!< Bit 1 */
Best regards
Peter
4 REPLIES 4
Khouloud GARSI
Lead II
Posted on December 23, 2016 at 13:12
Hi Peter,
Those code lines are used to define every bit's position in FLASH_ACR register (bit-field LATENCY).
To configure the wait states, you should use the definitions in ''stm32f1xx_hal_flash.h'' file.
If this answers your request,
please click on correct
Khouloud.
Peter Kietzmann
Posted on January 03, 2017 at 14:58
Hi Khouloud,
thanks for your response! I'm still not 100% convinced. Also as bitfield, this definition
would represent bit number two, right? But the reference manual states that bit number one must be set for two wait states.
Best regards
Peter
Khouloud GARSI
Lead II
Posted on January 05, 2017 at 15:19
Hi Peter,
You should not confuse between ''FLASH_LATENCY_2'' and ''FLASH_ACR_LATENCY_2''.
  • FLASH_LATENCY_2: is what you should use to configure two latency cycles (2 wait states).
    It's the second parameter needed by ''HAL_RCC_ClockConfig'' function.
  • FLASH_ACR_LATENCY_2: is the bit definition of bit N°2 in the ''FLASH_ACR '' register.
I hope this is clear now.
Regards,
Khouloud.
Posted on January 06, 2017 at 09:03
Hi Khouloud,
thanks again! Yes it's clear now. I was just too confused about the definitions in V3.5.0 of the header file which worked differently.
Cheers
Peter
