Why HAL_I2C_Mem_Read returns only 0?
‎2022-04-18 2:57 AM
I am using stm32f1 and HUT21D sensor (Temperature and humidity sensor). The sensor use i2c for communication.
I am using IAR and cubeMX.
For cube: I used default setting for i2c.
For IAR: I shared the main.c below.
Can anyone help on why only get 0.
#I2C​ #[STM32 MCUs]​
- Labels:
I2C
STM32F1 Series
‎2022-04-20 2:11 AM
I have a question. Sometimes I get HAL_OK and Sometimes I get HAL_Error. Is the problem with wires or not? I can't find why?
‎2022-04-20 2:32 AM
It could be the wires but 10cm is still a human distance. Did you measure with an oscilloscope SDA and SCL? Are the waveforms clean?
‎2022-04-20 3:42 AM
It seems that one the capacitors was not correctly soldered and it change the ground. it works for now.
Thnx everyone.
- « Previous
- 1
- 2
- Next »
