why does the microcontroller lose the program when power is off?
‎2019-11-26 3:19 AM
‎2019-11-26 3:47 AM
When the code is loaded to RAM by the debugger, and executed there.
Check your project settings.
‎2019-11-26 3:47 AM
Write your program so that it resides in FLASH, rather than RAM.
Read the manuals for your toolchain to understand how to locate code.
PS. Please change your username to a nomal nick.
‎2019-11-26 6:12 AM
An information packed post...
What micro-controller?
What board? A custom one?
What tools are you using to program?
How have you checked the code is lost?
What is going on with your BOOT0 pin?
‎2019-11-26 7:08 AM
It's a STM32F446VE microcontroller used by the BlueCoin development kit.
I'am using IAR Workbench IDE and ST-LINK programmer/debugger (integrated on STM32nucleo board) ;
the firmware implements a dataLog with USB interface; after program loading (the firmware is correctly operating), i disconnect the board from my PC (board power off) and at the time of a subsequently connection of the board with usb cable to my pc, there is no program running on the mcu, and i don't see any VCP on my computer.
‎2019-11-26 7:23 AM
Thank you!
‎2019-11-26 7:23 AM
Thank you!
‎2019-11-26 11:25 AM
Check the power, the oscillator (if external). In your code, why not toggle a pin every 500msec to at least know the code is running?
‎2019-12-01 2:33 AM
‎2019-12-01 2:33 AM
Hi!
Why should I check the oscillator?
