2018-03-23 11:43 PM
I used to use Cubemx to generate peripheral code not realizing that it got SYS > Debug ? Disabled the whole time. According to sources on the internet this means, no JTAG, no SWO as those pins were not initialized. Yet, I use Truestudio IDE and was able to debug all along. Could you please share some info on how this mechanism worked ?
I looked into project startup scripts, startup.s and there didn't seem to have any special instructions that could enabled SWO debug.
Thanks!
Jason.
#truestudio9 #swo-debugging2018-03-24 7:34 AM
The debugger controls and configures the micro-controller as it needs (clocks, pins, itm, dwt, dbgmcu, code/instruction injection, etc), it wrestles control of the system out of reset. You can break connectivity by fiddling with the pins later.
