2025-01-22 5:39 PM
To continue my studies, I need a Nucleo Board that has a µCU that is similar to the STM32H743ZIT6. Which would be the most suitable?
2025-01-22 10:43 PM - edited 2025-01-22 10:46 PM
Hello @carlosdelfino
i recommand you to use the NUCLEO-H753ZI that should be very simular to the board you are tooking about (almost the same with just cryptographie capability added to the NUCLEO-H753ZI).
Best Regards.
STTwo-32
Best Regards.
STTwo-32
