where can I find the tm32cube-fw-l4-v1120.zip
Wen Song Yuan
Posted on July 13, 2018 at 05:15
where can I find the tm32cube-fw-l4-v1120.zip ? Because the internet speed is too slow to update the stm32cubeMX automatically.
Szymon PANECKI
Senior III
Posted on July 13, 2018 at 09:26
Below please find a link, where you can download the package manually:
https://www.st.com/en/embedded-software/stm32cubel4.html
Szymon
2 REPLIES 2
Szymon PANECKI
Senior III
Szymon
Posted on July 13, 2018 at 12:48
https://drive.google.com/open?id=12JUPZc22Q6Y6M9utjc2laC5VIMBHZCZK
If you have poor/intermittent internet service I can probably create a torrent.
Watch also that you have enough hard drive space, the files are quite large, and unpack to 2x size, so going to want several GB free. CubeMX isn't always specific about the mode of failure, I've seen it report a download failure when drive space was tight.
If you run Win7 there is a bug where Microsoft packs the hard drive with log files, I had issue where those consume several hundred GB
