When Peripheral Library for STM32F2xx family?
infoinfo986
Posted on April 20, 2011 at 23:12
#lmgtfy:-firmware-library #lmgtfy:-firmware-library
12 REPLIES 12
Andrew Neil
Evangelist III
Posted on May 17, 2011 at 14:32
With a little thought, it's not really that hard to find:
https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/DispForm.aspx?ID=16297
luangzc
infoinfo986
drzile86
I think, but I'm not sure that, you can use std peripheral lib for STM32F1xx for standard peripherals like USB, I2C, USART, SPI.... Only different between STM32F1xx and STM32F2xx is that STM32F2xx are faster, and hve camera interface.
Dragan
Frankly you might want to try the most current download from Keil (MDK 4.14+) or a support package from Rowley.
http://www.keil.com/dd/docs/arm/st/stm32f2xx/stm32f2xx.h
infoinfo986
This is still not a solution but workaround. Does anybody ( including ST moderators) know where can I find peripheral library for STM32F2xx family?
If you are using this part, or planning too, you should call/email your local ST distributor/rep/FAE, and light a fire under them.
It really should be on the support website by now, but it's such an awful mess to locate things quickly.
infoinfo986
Andrew Neil
Evangelist III
Finally, it's arrived:
/ce74caf8
