2024-03-12
09:23 AM
- last edited on
2024-03-13
03:03 AM
by
Lina_DABASINSKA
I am using my custom board PCB with STM32F103C8T6 MCU. I want to give a PWM signal to PB1 pin & want to set PB2 pin to HIGH. While giving the PWM to PB1, although I set PB2 pin status as HIGH, when I measure the voltage of PB2 pin it shows '0V' value. I am using keil uvision to developed the firmware. How do I solve this problem? Can I set PB2 to HIGH while giving a PWM to PB1?
2024-03-12 09:31 AM
Should be workable. PB2 could be driven as a GPIO independently of what any other pin is doing.
Imagine that we can't see your design, wiring or code...
2024-03-12 09:31 AM
2024-03-12 09:39 AM
I cannot see your text fully. Can you repost it
