When debugging in STM32 ST-LINK Utility, there is a problem that device information is written as STM32F07x.
noplzz
Hello there,
I conducted the test with 2 types of MCU and the problematic model is STM32F401RBT.
If STM32F401RET is used, it will operate normally.
Is there a way to solve this problem?
I will need your support.
Thank you. ��
Guru
STM32CubeProgrammer may give different/better results. What is the origin of the problematic chip?
Thank you for your reply. ��
I will try again using the stm32cubeprogrammer.
As you know, it's hard to buy semiconductor parts on an authorized site recently, so I bought them at a local store, and is there a possibility that this part might be wrong?
I'll try to buy it again at another store. ��
