When assigning a pointer to structure pointer, mcu goes in to Hardfault Handler.
‎2020-03-25 2:34 PM
Hi Everyone,
When I send a structure pointer as an agument to a function, and trying to catch address of a variable in the structure in the function, MCU goes in to hardfault handler function. Let me simplify the problem as below,
uint8_t *ptr1;
uint32_t *ptr2;
uint32_t temp;
typedef struct{
uint8_t Data[10];
}example_struct;
example_struct sensor;
sensor.Data[0] = 0xAA;
ptr1 = &sensor.Data[0]; // here ptr1 is pointing 0xAA with no problem
ptr2 = (uint32_t*) ptr1; // here *ptr2 is 0x000000AA, so there is no problem.
temp = *ptr2; // here mcu goes in to hardfault handler
Do you have any idea why I am having this issue?
‎2020-03-25 3:38 PM
There is no support for unaligned accesses on the Cortex-M0 processor.
0x200000C9 is not divisible by 4
You'll need to read the value as 4 bytes and reconstruct the uint32_t from those.
‎2020-03-25 2:59 PM
No, your code works on my board as expected.
‎2020-03-25 3:10 PM
You're trying to read a word at a non-word aligned address. It may or may not work depending on your architecture. You don't specify what chip you're using.
‎2020-03-25 3:28 PM
@KnarfB​ @TDK​
Sorry for missing info. I am working on STM32F072 and using IAR as compiler.
Let me give you details step by step;
The address of sensor.Data[0] in the SRAM is 0x200000C9
I can see in the live watch ptr1 is 0x200000C9 and its value is 0xAA as expected.
ptr2 also has address of 0x200000C9, and its value is 0x000000AA as expected.
but when I try to use the value of *ptr2 it always goes to hardfault handler.
When I assign the address of 0x200000C9 to ptr1 manually (ptr1 = (uint8_t*) 0x200000C9) every thing works fine.
Do you have any idea?
‎2020-03-25 3:35 PM
@KnarfB​ @TDK​
I just noticed, when I modify code as below, also problem is disappears.
// ptr2 = (uint32_t*) ptr1; // this part causes the problem. I am using this part to convert 8-bit data variable to 32-bit variable.
temp = *ptr1;
‎2020-03-25 3:38 PM
‎2020-03-25 3:50 PM
@TDK​
Thanks for your answer.
I am not trying to devide 0xAA by 4.
Let say my array is like that;
sensor.Data[1] = 0xAB;
sensor.Data[2] = 0xAC;
sensor.Data[3] = 0xAD;
And I have a function;
void foo(uint32_t info){
I want to call this function as
foo(0xADACABAA);
I think the statement below should work;
foo(*(uint32_t*)&sensor.Data[0]);
However I always face with hardfault handler.
‎2020-03-25 3:53 PM
If you don't know what unaligned memory access is, there are many resources on the web. Here was the first result I found:
https://www.kernel.org/doc/Documentation/unaligned-memory-access.txt
Some architectures support unaligned access, but the Cortex-M0 is not one of them. That is what causes your hardfault.
‎2020-03-25 4:00 PM
I corrected my post. You are dereferencing an uint32_t from address 0x200000C9, which isn't divisible by 4. Not 0xAA. But the same problem.
‎2020-03-25 4:05 PM
This is the first time I heard about it. Thanks for the link. The only point confused me is the situation below,
Instead of declaring the array inside the strucure, I decleared as a global variable without structure. With this way it worked without any problem. So this might be because of array start address.
Thanks for your help, otherwise I could spend days to solve it.
