2020-10-08 8:21 AM
Dear st team,
What are the major changes in STM32F767BIT6 and STM32F777BIT6?
is STM32F767BIT6 code works in STM32F777BIT6?
2020-10-08 8:27 AM
CRYP and HASH IP enabled
Same die, same firmware
2020-10-08 8:27 AM
2020-10-08 9:41 AM
Hello @NJENN.1 ,
You can compare your selected products using 'Cross selector' feature with ST-MCU-Finder tool (or in STM32CubeMX, for more details on how to use this functionality, please refer to dedicated section "4.2.4 Cross selector" in this manual UM1718).
I attached the result of my compare between STM32F767BITx and STM32F777BITx, hope this helps you.
The STM32CubeF7 MCU Package is used for all STM32F7 microcontrollers.
Imen
2020-10-08 9:57 PM
HI,
thank you for your response. I have Stm CubeMx tool i got datasheets comarision.
Is their ant errata sheet for STM32F767BIT6 VS STM32F777BIT6.
2020-10-09 1:18 AM
Hi @NJENN.1 ,
Here is the Errata sheet applies to the part numbers of STM32F76xxx and STM32F77xxx devices: ES0334 STM32F76xxx and STM32F77xxx device limitations 6.0
You will find all resources related to your device in the product page, in the Documentation panel:
Imen
