2020-07-22 5:01 AM
2020-07-22 5:09 AM
Ok, and what's the question here? That the L4 needs to be suitable powered? Your own board, or some more standard one?
Remember you can edit posts, and add Title (short summary) and Body (actual question)
2020-07-22 9:15 AM
if using stlink its vdd is not a supply for the application, for example its regulator may overheat if your board requires over usb current budget such as 2G modems. stlink and application target supply should be independent.
