2017-07-04 01:45 AM
Hello Team,
While generating drivers for STM32F7 disco board with STM32CUBEMX tool I have faced the error saying THe HAL timebase source can e changed from the pinout tab under SYS. Please below picture. Can I still generate code or is it mandatory to change as per the warning and what would be the impact.
Thank you,
2017-07-04 03:34 AM
Hello
Arror.Balaraju
,You need to use other HAL time base than Systick and keep Systick as only FreeRtos Timer base to prevent dead lock issue.
I recommend to have a look to ' 4.6Setting HAL timebase source' inside the STM32CubeMX User manual
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Fuser_manual%2F10%2Fc5%2F1a%2F43%2F3a%2F70%2F43%2F7d%2FDM001047pdf%2Ffiles%2FDM001047pdf%2Fjcr%3Acontent%2Ftranslations%2Fen.DM001047pdf
Imen
2017-07-04 03:34 AM
Hello
Arror.Balaraju
Imen
2017-07-04 08:29 AM
I have gone through the document. I got answer to my question.
Thank you,
